rpoffen
1000 Posts Club!
The TCU tune is great. With no launch limiter, I can launch at about 2700 RPM and 6 to 7 PSI boost. Launches like a bat out of hell. I would say that one thing alone took almost 1/2 second off my 1/4 mile ET.yeah that is the correct way, think I will do the same. eliminate that connection there altogether. How do you like your Lozic ecu tune? I was thinking -10% but I see you are at -8%.
At -8%, it takes some getting used to the shift points when just around town, -10% would be more aggressive. The one thing I hadn't played with much at the track was paddle shifting manually, since the kickdown switch always causes problems. I have since put on the BMS kickdown blocker and will see next time at the track, which opens up Mar 1.
