You're entitled to your own opinion but not your own facts. All automotive manufacturers use the same basic techniques to detect flash tuning because they all buy their electronics from the same automotive electronics manufacturers. Flash tunes are easily detected after the fact even if flashed to factory and EVEN if you swap the ECU. In this case not only can they detect the ECU itself has been swapped but you'd have to change the computers for the trans, stability control, dash, at a minimum, to try to escape detection. Good luck with that.
There are lots of great reasons to flash your car but doing so makes it impossible to avoid detection later if that is something you're trying to do.
As for the prices flash tuners are trying to get, IMHO, totally ridiculous. For BMWs we publish free unlocked maps for use with the JB4. The flashing tools (MHD for example) charge a $79-$249 fee per
VIN for loading maps based on the value of the car. So to flash a $100k M5 is around $249 for the license then whatever you spend on the map. Even custom tuners only charge around $300 per map to make maps specifically for you. But everyone has to make a living and if people are willing to pay their price for disposable flash maps, more power to
VIN for loading maps based on the value of the car. So to flash a $100k M5 is around $249 for the license then whatever you spend on the map. Even custom tuners only charge around $300 per map to make maps specifically for you. But everyone has to make a living and if people are willing to pay their price for disposable flash maps, more power to them.
where are you going with this a spare ecu is undetectable because the ecu is where the values are stored and recorded. When you unhook your battery, the ecu looses power and shuts down. Then after 12 months on the shelf when you bring to dealer for whatever reason you put your UNTOUCHED NOT TAMPERED WITH ECU back in the car it turns back on and your fine. Btw be carful how you respond because if your going to say readings are recorded Somehere elce you essentially are telling all your jb4 users they just got f&*%ed. Also go lookup and find the codes and code it into the jb4 software it’s kinda anoing having people ask what there codes mean.
