Snicklefritz
Sustaining Member +
- Nov 28, 2022
In all your surgery you might have gotten some fluid on the outside of the engine/trans, and it is burning off? Just a guess.
This was my second guess since I did leak some coolant while trying to fill up the radiator and while replacing the bleeder hose. I just wasnt sure if coolant burned and created smoke like that. Then again thats me assuming coolant acts like water and would just "sizzle" off when hotIn all your surgery you might have gotten some fluid on the outside of the engine/trans, and it is burning off? Just a guess.
I believe there is still room for transmission fluid since my car seems to be shifting weird sometimes during the first few minuets of driving.
Unfortunately I rarely use my paddlesGood to know that you don't have a bad fluid leak causing smoke.
What does shifting "weird" mean? I almost always use the paddles. Sometimes the shift feels like a "bump" rather than just a smooth shift. This is a lately thing, as in this has only been noticeable for a few months. It doesn't seem to be getting more pronounced, so, Ima not too concerned at this point.
. I blame the fact that I was so surprised and proud of myself for being able to replace the trans pan, fluid and verifying that the car was shifting afterwards, that I didn't notice that the car needed another 1.5 quarts in it.You don't have to shift down. Just let the car do that part. Shifting down a couple of gears to pass quickly is a nice option though.Unfortunately I rarely use my paddlesalthough i would like to learn how to properly use them and when to accurately shift up/down.
Thanks for helpful insight on using the paddles! I will definitely take all of this into consideration and will look into using them more often if it means keeping a bit more like in the transmission in the long run.You don't have to shift down. Just let the car do that part. Shifting down a couple of gears to pass quickly is a nice option though.
The thing I like about using the paddles is a feeling of engagement, coming from years of half my vehicles having manual transmissions. My first car, a Bug, was of course a stick on the floor. Loved that about it. If the Stinger had a stick option I would have insisted on it.
"Accurately" shifting is any time before you pass 5000 RPM, because if you wait that long the car will upshift for you. So, if you engage the turbos be ready to pull the paddle or the car will call you an idiot by upshifting on its own.
The other thing I like about using the paddles to hold onto a gear is that the trans is shifting less often, which has to help prolong the life of the trans, but this is only a thing if you plan on hanging onto the car, which I do.
Low transmission fluid will explain everything that you've noticed. I know that you feel bad already. I doubt that you've damaged anything.
As far as temperature goes, the auxiliary gauge is for engine oil temperature, not trans fluid temperature. Do you have an aftermarket transmission temperature sensor?
Anyway, as far as the oil warming up goes, mine definitely takes longer than ten minutes in colder temperatures to get up to c. 200F. This is for the GT1. The Premium does not have a "Gauges" screen, and only has the coolant temperature gauge. Interestingly, this sole gauge takes at least twice as long to move as the same gauge in the GT1. I don't know this, but assume that the difference is tied to the lack of an oil temperature gauge, so that the only gauge the Premium has functions as an indicator of both oil and coolant coming up to operating temp. But it could just be a difference is individual gauges and have nothing whatsoever to do with oil.
Not every day for me at over seven and a half years in.That is interesting, feels like I learn something new about the stinger everyday recently![]()
