just some help!
chivasGT2
do i need oil catch cans for the gt2 and jb4 tuner? do i need 1 or 2 oil catch cans? denso spark plugs or hks spark plugs? do i need to buy a chip to go with the jb4 tuner? which chip to buy? i did a muffler delete and purchased the jb4 tuner/bluetooth
Yes you need spark plugs for jb4 .. either ones will work even stock plugs gapped smaller. Catch can is a debate not really needed but some prefer them. And you would need two if you got them
thank you!!!
We're working on a clean plug and play Stinger OCC kit too, BTW. :)
I’m currently looking at the Denso plugs that terry reccomends from burger since they are much cheaper than the hks plugs.. like 9 dollars a piece
If changing plugs to non OEM, do not safe a few dollars here.
They are inside your engine. If they fail it is going to be expensive.
If you are going to increase the boost, cheap parts is NOT the way to go!
Terry is running them no problems on car.. I might go with hks but unsure which ones would be best
Denso is not cheaping out. They and NGK make the plugs for HKS. There are only two other manufacturers - Bosch and Champion.
Correct. My comment was more pointed at warning for cheap
