wildpig1234
- Nov 19, 2022
damn... warranty voided by oil ;(The last owner’s tuner parts that voided the warranty was 10w-60 high perf blinker oil.
Muddah fakars
Muddah fakars
What were the issues with yrs? Did they ever get stuck in an unusable position?
As of right now, even though my dbl warning light is on, it seems like the up and down is still working and I can still get good front illumination. I don't want an issue down the road when it would be a problem though.
Yeah, mine may be the same too. Just annoying to have that dash light on. esp since this car is only 34K miles. You really shouldn't have any check light on until at least 150K miles IMO... lol... My 2004 G35 with 188K miles still run well with check engine light that comes on once a while but then it clears itself after a week or two...lolThey still worked and I think went up/down, just didn't do the left/right shimmy. Plus the idiot light in the dash was on.
Left as in driver side or passenger side (looking at the car from the front or what you see looking out of the car from inside).My left headlight in post #4 is what they are "supposed" to do as the startup sequence.
Found the bulletin in another thread on this forum.Kia mentioned there was. I can't seem to find any Info on it though. What my dealer mentioned awhile back vaguely.
You're a saint.Found the bulletin in another thread on this forum.
You're a saint.
Wonder if I can order these.
kiapartsnow.com lists them, like less than $9. But kiaparts.com, when I punch in the number, goes to the page for the old part number, since the TSB was dated June 2022, it might not have made it to all the parts catalogs. Might have to call them to make sure it is really the updated part.You're a saint.
I would, print out the TSB and tell them to follow it. If it meets the requirements, they should replace it.So i should press the dealer to replace these parts under warranty! This is total BS what they are doing to me by refusing to service the headlight problem making some BS about nonexisting tuner parts!!
Seems like do it yourself and straight forward if I was the OP try ordering the part and do it at homeI would, print out the TSB and tell them to follow it. If it meets the requirements, they should replace it.
It's actually quite easy / convenient.I don't know what exactly the problem is. It might very well be that but i don't know because that fkin first dealer refused to tell me exactly what the problem is ;(
Also, i have no idea how hard or how long it would take to disassemble the headlight units ;(
Yes, this is an easy and cheap repair. Just did this myself on my GT2 last week and all good now:It's actually quite easy / convenient.
there is an access port in the wheel well/fender liner.
Does this help.
Start around page 5 of the attached .PDF
Dynamic Bending Light Failure
I ordered the parts from Kia.parts:Can you link me on where you bought it? And aside from twisting and replacing the bracket piece, anything else did you do? Disconnected battery etc?
Amazing. Thank you!I ordered the parts from Kia.parts:
No need to disconnect the battery, just remove the two push pins shown on the TSB and unscrew the dust caps to replace the brackets and current foam. Might not be a bad idea to order a few additional push pins as well, since they do break easily.
I'd be down to trade with ya lolSo there is a happy ending. The other kia dealer i took it to didn't ask any question and replaced the driver headlight within 3 days under warranty. Don't know what the other first dealer problem is .
Now i have to figure out what to do with this loud exhaust. lol
