transferCASE
- Aug 23, 2021
Hey guys
I just installed the 2022 JUN BL EVC exhaust (from K8 Stinger store) on my '22 GT Elite 3.3TT. This is the electronically actuated valve kit which uses a radio transmitter installed in the truck with the battery and a remote to open/close the valve (buttons labelled 'on' and 'off'.... hm).
I thought I'd try plugging the OEM plugs on the exhaust in the hopes they'd work, but I think the larger valves likely require significantly higher voltage as they would not open. The JUN BL system makes a pretty good thunk when you open and close it.
I plan on testing the OEM plug voltage to see what it outputs when switched to sport mode, and then test the voltage from the JUN BL unit. My question is, if I have a target voltage, how do I go about stepping up the line voltage for the factory signal to act more as a true plug and play solution? I'm hoping to do this to get rid of the remote system as I am somewhat concerned about parasitic battery drain from the transmitter. I want to avoid having to install an on/off switch, as it would only power the transmitter due to the single-plug nature of the transmitter system design, and I'd still have to use a remote. PITA.
Pretty happy with the exhaust and the valve system as a whole! I do wish it was truly plug-and-play though.
