MerlintheMad
10000 Posts Club!
I'm assuming that none of these shifting issues occur if you use the paddle shifters (manual mode). So while working out what is going on you can still drive the car. Right?
I better start using the parking brake......13,000 KM, exactly what was mentioned above. 1st to 2nd is rough and have a rev spike. I also had park fail on me last night. After going into park in my driveway it rolled backwards. Dealer cant figure either because they cant reproduce it
I can drive the car with no other issues. It's odd to me that the 1-2 shift can be so rude, then the rest are smooth as silk. So it kinda stands out. I can't imagine this is something they just overlooked or didn't think mattered.I'm assuming that none of these shifting issues occur if you use the paddle shifters (manual mode). So while working out what is going on you can still drive the car. Right?
It's a good idea, and takes stress off the transmission's parking pawl. I really wish the EPB would just automatically engage when you turn the car off - it already disengages automatically when you shift out of park.I better start using the parking brake......
I don't know how rude you're talking, but the 1-2 shift is always going to be a little more jarring than any other shift.I can drive the car with no other issues. It's odd to me that the 1-2 shift can be so rude, then the rest are smooth as silk. So it kinda stands out. I can't imagine this is something they just overlooked or didn't think mattered.
Hi scotte. My GT2 AWD automatically engages the EPB when I shut the car off. Unsure why yours would behave otherwise.It's a good idea, and takes stress off the transmission's parking pawl. I really wish the EPB (Electronic Parking Brake) would just automatically engage when you turn the car off - it already disengages automatically when you shift out of park.
Car is drivable, not a limp-mode issue. But disconcerting.
I have not tried to simulate this with the paddles but, honestly, I feel that the computer has more control if it's doing the shifting on its own terms without me throwing in unknown variables. Ergo, it shouldn't be doing this during normal operation. The feeling of slipped shifting and jerkiness occurs under light load, not hard driving, which is also confounding.
I generally don't use the paddles much because the car keeps reverting to D at stops (which is pretty annoying). I used to use my Camaro's paddles all the time, but it was a lot more gratifying and fewer gears to manage (six).
Hi scotte. My GT2 AWD automatically engages the EPB (Electronic Parking Brake) when I shut the car off. Unsure why yours would behave otherwise.
I think the EPB engages automatically if Auto Hold is on, when the ignition is turned off.My GT2 AWD most definitely does not automatically engage the parking brake.
I think the EPB (Electronic Parking Brake) engages automatically if Auto Hold is on, when the ignition is turned off.
So it only happens when I have “auto-hold” enabled. That seems to be the trigger when shutting the car off to auto-engage the ePB.My GT2 AWD most definitely does not automatically engage the parking brake.
I'm guessing regular brake.Does auto-hold use the "regular" brakes or the e-brake?
During driving, the regular brakes.I'm guessing regular brake.
My GT2 AWD doesn't engage the EPB automatically, but I definitely use it any time I am parked, unless it's perfectly flat. Been trying to get my wife to do it too cause our driveway is angled, but she parks in the garage now, so less of an issue.Hi scotte. My GT2 AWD automatically engages the EPB (Electronic Parking Brake) when I shut the car off. Unsure why yours would behave otherwise.
The electronics in my Stinger are a little deeper than what's in my Fox 5.0.I think the EPB (Electronic Parking Brake) engages automatically if Auto Hold is on, when the ignition is turned off.
The last sports car I bought was an '06 stang gt.......I was just thinking about the ''bareness'' of the cabin...pretty much nothing compared to the stinger. Couple things irked me about that car, the paint job sucked and the spark plugs needed a miracle to keep them from breaking when removing......and when they broke you were screwed. and the live rear axle...another term for lack of cornering.The electronics in my Stinger are a little deeper than what's in my Fox 5.0.
