Some say the race chip is not a good product ?
I don't plan to do any
mods on my car.
I now only have drop in K & N air filters in oem boxes and 2 JA snorkel air scoops, which seem to have shortend my 1/4 mile times by 0.25 secs.. I believe.
I don't mind to change spark plugs soon to a better model, but other than that I'll not do anything else, except for adding a tuner.. and running 91 octane daily and 93-94 on drag strip days.
I don't know how the maps work. I believe my car can never run past map 0-2 maybe 3 ? as higher maps are only for
mods, other fuel sources, etc etc..
So, do I need just a simple Racechip with 5 maps or ? ? Do I need the app ? or is the Racechip S no app., o.k. I just go under the hood and flip button to diff. setting ? or does the app do more than allow you to switch from the cockpit ?
Going to GTS model, and possible gain of 133 lb.ft torque must be only for fully mod'd cars ?
And is mapping similar across these main brands ? How do they work
If I'm on my set up with 91 octaine, what would be my mapping and how does it work ?
Can I choose map 1 and 2 on 91 ? how about on 94 octane ?
Or do they work where, if using map 2, you can only select that if running 93-94 octane ?
You can't select map 3 if don't have this or that mod ?
I really don't understand the details and variable yet, so any really detailed response, is appreciated.
Are they all the same generally ?
I don't want to spend $800 plus for a tuner, if my set up only needs a less costly model
