That’s the only thing I can find that matches symptoms. Runs perfect stock or Map0, but anything above that is a no go. A new set of coils are on the way, but want to make sure I cover all bases in case it’s not a coil issue. Physically they all look new and good.Damaged coil?
Out of curiosity, why does a weak coil or plug misfire cause the JB4 to stop reading and freeze?Hopefully it's the coils because if not then that just leaves fuel injectors. Does the JB4 "cut off" it's logging when it happens? If so that is a give away it's a plug/coil and not an injector.
They are brand new plugs. Stock plugs were gapped to .024” first and same thing happened. Hoping it was plugs I installed the new “recommended” HKS plugs gapped to .023”. No change.It’s worth pulling the plugs and putting new ones in before you shell out for new coils. I was having the same issue with fairly new plugs and I guess when I gapped the new plugs I bent the electrode some how and that was causing my problem.
Hey Punkin, were you able to fully diagnose this issue? Was it coil packs?I have a 19’ GTS with K&N intakes and secondary cat deletes, 1,400 miles on the car. Just installed the JB4 and HKS plugs gapped to .023” and on anything above Map 0 it cuts out as soon as boost hits 2-3psi. What am I missing? What could the issue be? I’m at a loss.
I've seen logs from 19 cars showing strange things on higher maps ...
You think the 19/20 models had ecu parameter revisions?
