3.3TT JB4 Map 2 log check, CEL 061B after
I had this code a few times early on. It was a torque management code. Basically car would start running weird, then go into limp mode. When I shut the car down for 10+ min and cleared code it was like it never happened. Not sure if it's coincidence but it hasn't happened for 3 months or so since last update.
Yes fault was a known issue caused by a JB4 mobile change and resolved.
Hi Terry,
I installed my JB4, intakes, OCC and plugs last weekend (450hp) kit, running 91 octane and just got this 061B code this morning. My first logs from last week were pulling too much timing on map1 (I was thinking bad gas after talking with a few others here: 3.3T New Install Log Check - Map 1).
I have been running in map 0 since Tuesday (6/15 while I ran through the tank). I filled up with top tier gas on Friday (6/18) and took the car out to our inlaws 90 miles away. I was leaving it in map 0 until I had a chance to run through more gas and verify logs. On the way home this morning I had the engine shut off after moderate acceleration less than 3 miles from home. I turned it back on and then almost immediately it went into limp mode and code 061B came up.
Based on this thread, there was a known issue last year with the mobile app but I am on App Build A347 and Firmware 21/22//5. Do you have any ideas on what I should check?
Other notables, it was raining pretty hard for most of the drive today of the 90 miles. Ambient temp is around 60*. I had some hard acceleration along the drive to pass a few cars, but generally did not beat on it. I was in Eco mode for the entire trip. After the car stalled, the shifts were really rough (which seems consistent with the other instances of this fault on here.
Here is my latest log from Friday on map0 before refilling fuel:
Hi Terry,
I have been having this same issue it seems to happen more on a rainy day idk if that has something to do with the issue
Have you been getting the fault more than once? I only got the fault one time in the rainy conditions, but I haven't had to drive in rain like that since then. I drove in ~10 miles of rain on my last road trip a week ago with no issues.
I did have a conversation with Burger support and Terry and we never did get to what caused the fault and since it only happened once, it was kind of ruled as a one off.
I know that's not the most helpful, but I am interested to see if we could figure out a cause.
I had it happen a few times in the past couple months I just redownloaded the lasted firmware and the car feels way better and I haven’t had that code come up yet I’ll let you know if it happens again
