stngr_gbrl
- Jul 7, 2023
What fuel are you running now? 93+E30 might make map6 usable if that’s a really good 93 before the mix. Pump 93 alone good luck for able to support map2.
I run 93 on MAP3, with no problems.What fuel are you running now? 93+E30 might make map6 usable if that’s a really good 93 before the mix. Pump 93 alone good luck for able to support map2.
Check your log. If it’s clean then use the Target in your log as a baseline for map6. Map3 is 6psi tapers to 5psi. So start with 5psi flat on map6 and add more boost for 5000, 5500 and higher.I run 93 on MAP3, with no problems.
What about fuel Bias? I run map6 just like you instructed me a month ago.Check your log. If it’s clean then use the Target in your log as a baseline for map6. Map3 is 6psi tapers to 5psi. So start with 5psi flat on map6 and add more boost for 5000, 5500 and higher.
What plugs you use ? and gap ?What about fuel Bias? I run map6 just like you instructed me a month ago.
I think it's a clean log and I also sent it to Terry, and he also approved it. But what do think?
Yea I had them for about 500 miles now and I do think they make a difference in MPG and engine sound.Your logs look really clean ! just installed new oem coils also.
