I would like some help creating a custom tune for MAP6 on the JB4. I am running BMS Intakes, HKS Sparks, BMS OCC, and the JB4. Soon to be installed: MBRP Pro Catback and Velossa Snorkels.
What fuel are you running now? 93+E30 might make map6 usable if that’s a really good 93 before the mix. Pump 93 alone good luck for able to support map2.
Check your log. If it’s clean then use the Target in your log as a baseline for map6. Map3 is 6psi tapers to 5psi. So start with 5psi flat on map6 and add more boost for 5000, 5500 and higher.
What about fuel Bias? I run map6 just like you instructed me a month ago.
I think it's a clean log and I also sent it to Terry, and he also approved it. But what do think?
Yea I had them for about 500 miles now and I do think they make a difference in MPG and engine sound.
I also just placed an order for a 1.4 bar 91 Octane tune from Lozic, but I will be running E30 with it.
