Ek9max
I honestly think it looks pretty good. Like a sportier version from kia.
Update after adjusting the height.
Sorry to disappoint the crowd, but I finally only lowered it further by 10mm in the front and 7.5mm in the back.
Edit: NVM, I just measured and compared to the previous pictures, it is actually 16mm lower in the front and 11mm lower in the back!
There are a lot of speed bumps and underground parkings in Korea. I did not want to have to worry in front of each speed bump and have to take ramps in diagonal in fear of scratching the bumper. So it may not look as cool as people on Eibach's, but I am pretty satisfied with that height for the moment.
Comparison:
Front:
38mm->22mm (-16mm)
Rear:
31mm->22mm (-11mm)
Thank you for everyone's feedback!![]()
Oh You are right first and second pic are the same!
Is there any bouncing over road surfaces with these KWV3s?
Which bounces more, the front or rear?
What shock settings do you have your shocks at?
Do you ever feel any bounce or float? Where, front or rear? When?
Give us a review of the ride quality.
Has road noise increased?
Looks very good.
They are in my signature but here you go:Could you tell me your wheel setup? I see you are on stock tires. Thanks
I think "Now" looks perfect.Oh You are right first and second pic are the same!
I wanted to make it easy to compare, but it became even more confusing, let me try again:
The last one ("lowest") is only to show how it would have looked if I lowered it further.
It is subjective alright. And it can vary from ride to ride. We can fool ourselves into believing a ride is too soft or too hard.As for the ride quality, I find it to be even better than stock. (that can be subjective)
What do you guys think?
I understand your point and I do not disagree. They did more tests than anyone on this car and the settings they've chosen were the best compromise to achieve the result that they wanted for this car concept. But as said, a compromise means that they need to satisfy the widest range of customers with different needs and expectations.It is subjective alright. And it can vary from ride to ride. We can fool ourselves into believing a ride is too soft or too hard.
Here's the thing about the stock Stinger: it is a compromise. There isn't anything untested about the Stinger. When Biermann says the rear end is designed to be a bit "playful", he's not just using handwavium to brush aside complaints about the rear end being "floaty" or moving around too much when "spirited" cornering or high speeds are happening. He's talking about how the rear end changes. For 99% of the time (and 99% of drivers, i.e. "normal" drivers simply traveling) the rear end is compliant/comfortable at speeds well within 100 MPH (legal speeds). But the car's potential is there bone stock: it can go fast, and it won't feel floaty at all to an experienced driver who knows what the car is designed for; s/he will adjust to the characteristics of the bone stock setup; and observe that improvements can be made, but the car is really good as-is: which is a Gran Turismo that can carve curves. The faster it goes the more hunkered down it gets, bone stock. When we put these suspension mods on, we get the buttoned down feel at "normal" speeds, and the faster speeds should be even that much better vis-à-vis traction and smooth cornering.
