Hello
SAYWHN
Stinger GT2 - looking to remove headlight assembly that has alot of condensation build up inside
Howdy. Welcome to the forum. :thumbup: That is a comparatively common complaint that mostly goes away by itself. Unless the housing is defective, Kia won't replace it for condensation.
I disagree. The entire assembly should be completely sealed. There should be no condensation build up inside of the headlight assembly. When there is condensation build up inside a headlight assembly it usually means there is a breakdown in the surrounding sealant.
@Daniel Hutnick , you should really get the dealer to take a close look at it
