Hi there. Welcome aboard! And thank you for signing up.Stinger GT2 - looking to remove headlight assembly that has alot of condensation build up inside
I disagree. The entire assembly should be completely sealed. There should be no condensation build up inside of the headlight assembly. When there is condensation build up inside a headlight assembly it usually means there is a breakdown in the surrounding sealant.Howdy. Welcome to the forum.That is a comparatively common complaint that mostly goes away by itself. Unless the housing is defective, Kia won't replace it for condensation.
