Kamauxx
5000 Posts Club!
- Jan 28, 2018
t 40...it's a big 'un
Yep. Biggest in my lil ole set is a 30. I still managed to get one loose but gave up on the rest.
Just be thankful it’s not red loctite, you would never get it loose unless you apply heat.
Agree, but with red you will need oxy-acetylene heat to loosen them.Blue is also designed to loosen grip with heat - just slowly and carefully apply to the surrounding metal parts with a heat gun or hairdryer.
Weird this is still a problem. Did you guys get the second fix from Kia? I had 2 TSBs on it. The first worked for a month, the second I’ve had no more rattle.
I've used a lot of Loctite Blue (great product), but never had to use heat when removing fasteners assembled with it. Heat will help loosen any threaded fastener, whether Loctite was used or not, but would rarely be needed. Per the company's own literature: Loctite® Threadlocker Blue 242® is designed for the locking and sealing of threaded fasteners which require normal disassembly with standard hand tools.Blue is also designed to loosen grip with heat - just slowly and carefully apply to the surrounding metal parts with a heat gun or hairdryer.
Any time I reassemble a part that had Loctite on it, I thoroughly clean the threads of any residue, then reapply new Loctite before putting it back together. The product cures in place when air is excluded from the tightened part, and isn't designed for re-use.Yep, blue loctite, they didn't skimp on it either....shouldn't need a second application.
I try to avoid them as much as possible. I had them fix my rotors a few days ago and that "it'll be about an hour" ordeal turned into a 7 hour nightmare.
maybe not designed for reuse, but it still does it's job the 2nd time around.Any time I reassemble a part that had Loctite on it, I thoroughly clean the threads of any residue, then reapply new Loctite before putting it back together. The product cures in place when air is excluded from the tightened part, and isn't designed for re-use.
The quote you provided from Loctite confirms that 'They cure at room temperature to a hard solid thermoset plastic when applied to metal fasteners and in the absence of air', as I stated - why do you consider that mistaken?as for the ''red'' quote, air is what turns it to a plastic solid....not the otherway around as you mistakenly posted. Here is a answer from loctite if you think I'm full of b.s.,lol
Just got done doing my trunk area..........half hour tops, I cleaned it with alcohol first.......helps with adhesion when it's cold ''frost king'' is the brand and under 20 bucks at any home depot.Thanks for posting that video, that is very helpful to Stinger owners trying to figure out how to put an end to this hatch rattle issue. I will do this on my Stinger because the hatch rattles like crazy now at 6K miles ! Also very nice sound deadener application. That section where he applied it is the biggest difference why the KIA Stinger has more road noise then the Genesis G70-G80. Both those cars have sound deadeners in the truck area under the car the Stinger has none.
