The RWD specific set (30mm/20mm) is categorized as part#28701-2 BUT are supposed to include the same rear springs (20mm) as the AWD #28701-1 set. The front springs should have the #28701-2 stamped on them. The rear springs (20mm) should have the #28701-1 stamped on them - see post #147
So, when you buy the #28701-2 RWD specific springs you should receive:
- a box that says #28701-2
- two front springs stamped #28701-2
- two rear springs stamped #28701-1 (20mm)
But the link to K8’s H&R spring set is a 30mm/30mm drop and H&R’s AWD springs are supposed to be 20mm/20mm (same rear springs)??
@Daniel @ K8 Stinger Store could you please provide a part number for those H&R springs?
@Wascalwabbit77 your stinger looks great but from that angle that looks like an even drop without rake but the pictures in your post #147 in this thread your front springs are stamped #28701-2 and rear springs stamped #28701-1 Could you take a picture straight on from the side please
