Fog Lights / Daytime Running Lights
Waiting for diffuser so it looks luxurious, not as garage DIY :) And better color match (or diffuser can have matte)
Wow, somebody had the same idea as me! :p
kia-stinger-fog-lights-jpg.1250
Fog lights are a little brighter in color.
Jong Ki, I suggest you have the engineering team work on an exact color temperature and brightness match. You may then have a "hit" on your hands... :)
you gotta keep away from the new dispensary .....................those edibles !!!!:rolleyes::rolleyes::whistle::whistle:
Companies in North America can easily handle this sort of project as well--and often build to spec based on what the community asks for, not what's being thrown together in Korea. You guys don't always have to run to Ebay for goodies like this. ;)
do you have anything ??
Hey Import. you see the irony in what you are saying and your name..:) Just saying..
I dont think any vendor should be poking any other vendors or members in the eye ! If they want to be here they should provide the members with solutions and options , not attitude . Sharky has a bad habit of being critical ..................:thumbdown::thumbdown::thumbdown::unsure::unsure: just saying too !
[인용문 : "moinmoin, post : 23386, member : 158"] 종기, 정확한 색온도와 밝기가 일치하는 엔지니어링 팀을 운영 할 것을 제안합니다. 그러면 손에 "히트"가있을 수 있습니다 ... :)[/ QUOTE]
Produced in the same color as the genuine headlight
Perhaps it may not be possible.
Aftermarket LEDs
There are so many LED types ...
Most of them are produced at 6000K.
Most of the genuine car is about 5000K.
I will offer to the manufacturer ...
Is adding the diffuser something that can be done as well ? , it would really finish the look I think we are trying to achieve :thumbup::thumbup::thumbup:
Do you know the rear side reflector strips?Well, there is a light at the end of the strip and, But not for OZ, again. In the manual it says that it has the fog lights and the light switch lever/arm (turn signal arm) has the switch! But not here in OZ.
If you look closely there is a small rectangle for the fitting ( closer to the rear end) which means one could wire it as an additional turn signal or just a light for night time driving!
In the US MANUAL,
Light Bulbg Position (Rear) Pic on Page 7/79 does not show or mention Fog lights.
In the OZ Manual it does (maybe a different page), but not available here.
Here is the page in question from the US Manual. Have circled the area, like I said I have it but not operational, maybe turn it into a turn signal light!!
At work now, maybe somebody else here from OZ who can access the manual and post a scan or pic.
If not when I get home will do.
I'm pretty sure, but not positive, that is the switch for the REAR foglights mandated in parts of Europe.
That needs to be mandated in the US. It's smart and looks pretty cool, too.
