Exhaust tips (2022)
Because his sizes are almost same size if not bigger than OEM and it would rub, but in his pictures there is a bit of a gap.
Better safe than sorry, I reckon. 5mm bigger wouldn't do much beyond adding risk to rubbing or melting something. Looking at AliExpress it appears that all or at least most of the tips with that size of outlet are unavailable. At least we have the relative size, though.
Can anyone please tell me the diameter of the stock exhaust pipe itself? I don't have my '22 yet, so I can't check this myself.
It’s 54mm I think.
  • Like
Reactions: KAS
I ordered two sets of tips from AliExpress, 105mm*130mm outlet with a 54mm inlet, I'll let you guys know how they fit on my 22 when they get here. I'll probably sell the extra set on here once I verify fitment and ensure the tips aren't total garbage.
How did they fit? Trying to order some today. Which ones did you end up purchasing and how was fitment? Did you have to order any other hardware or does it fit fine with the OEM hardware?
I've pretty much given up on trying to find tips for the 2022.
Been delayed in sorting them out, but it looks like they will fit well enough. I'll keep you posted.
The measurements seem to line up with the 2022 and 2023 OEM exhaust tips. Would these AFE tips fit?
  • 2 1/2” inlet x 4 ½” outlet x 7” overall length
I have a 2022 as well I wanted to put some tips, but my local exhaust shops say there are options that will work, but nothing won’t fit right or look good
someone on another thread says they saw someone running Akropovic tips with the 2022 rear diffuser and posted this picture, don’t know what size tips those are, but I personally would not want to run that since that gap around would drive me crazy
Agreed on the space but I understand why they installed them so you take what you can find. I’m in the process of searching now for installation on the new MBRP system.
Any input on tips for the 22-23's definitely need them now with the exhaust and dp's thanks everybody!
On another thread it was just stated that MBRp is developing tips for stingers. No release date but they are in development.
I have a 22 Stinger. I’m trying to take off the OEM chrome decorative exhaust tips to have them Gloss black powder coat. I tried to take them off today without success. theyre attached with the 2 bolts (easy to remove). And 2 screws. 1 easy one not easy. The outside/exterior screw is very easy, but I can’t figure out how to remove interior/inside screw. How did folks remove that screw?
hey guys! Believe the correct size from AliExpress is 105mm*130mm for oval CF tips. This guy with the tips said his size was 110*135mm and then deleted his comments after. I think he doesn’t want anyone to know so they can sell them for a lot of profit.
Ps. Stock 2022 tip size measurement pictures attached aswell. It’s not my pics.
did anyone find the link to buy the 105-130? I have the 2.5" MBRP, 63MM good?
I did this the first time but now I just remove the whole lower bumper piece with the tips and all.
It has been confirmed by a Stinger member on Facebook that the size I stated is correct.
The correct size and link is posted on this FB post. If you can’t see it then I’ll post.
