boosted1g
Sustaining Member
When I ordered my rear, Eibach missed putting their little tube of grease in there so I just used my own silicone grease via zerc fittings and have had no issuesAnd whats your experience been with creaking? Ive been seeing mixed reviews from ‘totally silent with a greasing’ to ‘continuous creaking after greasing and teflon wrap application’
When I put on my front I used the supplied grease and it squeaked. So I lifted the car back up and used the zerc fitting (and triple checked my torque) and it is now quiet like 97-98% of the time.
FYI the front bar just went on last weekend, the rear bar about 5-6 weeks ago. So my time frame is not a very good long-term measurement.
The roads here are pretty crappy and this is my daily driver. When I put the rear on (soft setting) It had some improvement in handling with no real noticeable difference in ride smoothness. When I put the front on, I left the front as soft and put the rear to firm (as advised by other forum members). However, it was just a little too bumpy for the "family car" so I moved the rear back to soft. Now it is just within acceptable for smoothness, while still having a good improvement in handling.
If this was simply a "fun car" that I would leave in sport mode, then I would have kept the rear on firm because the cars handling was great.
Also, if you do go for the sway bars, so you dont have to look it up elsewhere: the torque is 45 ftlbs for the bushings and 80 for the end-links.
