The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Advertise with us!
Promo code: REDLINE
Can you provide the page reference in the manual? I've looked but maybe not hard enough. Thanks.In my GT2, the seat automatically slides backwards and the steering wheel lifts when I power off the vehicle. The amount the seat goes back is configurable in settings. IIRC, the default setting on mine is not the furthest back it can be set to go. I wonder if something's interfering with the seat (interior panel w/seatbelt housing?) when it goes back far enough. I sure hope they take care of you 100%!
Ouch, not good....do you wear a belt? do you carry a wallet in your back pocket?
Also when you get out of the car where do you place your right arm/elbow? if found myself pushing against the right hand bolster to get out, have to make a consious effort not to do this. Just putting a couple of things out there, let’s hope it’s the cow’s fault & it is replaced under warranty![]()
I'm hearing you - its like reading.....oh, I don't know...some type of old school instruction manual.Unfortunately, I've not yet cracked the manual. It's in the settings you can get to in the display.
Current settings in my car its about an inch in front of the B pillar. Then it moves forward once ignition is pressed.I took the occasion today to try to look over the side bolster of my seat. I have NO idea how you could do that to the seat. It's not even exposed when I get in and out of my car.
Yep, not holding up well at all.non seating surfaces like that outside bolster are probably not leather. usually it's just where you actually sit that has real leather
still a synthetic material or real leather should hold up better
I'm now getting into the car via the sunroof.
OMG , you pushed over June Cleaver .................it cant be that bad !
I thought it was an image from an instructional video on how to get into the car without touching the bolster....OMG , you pushed over June Cleaver .................it cant be that bad !![]()
remember to take your tool belt off this time ! and unplug the disc sander !I'm now getting into the car via the sunroof.
The toolbelt automatically attaches when I slide down the batpole.remember to take your tool belt off this time ! and unplug the disc sander !
Found it - now on extended. Seems to have made bugger-all difference but hopefully it will be enough.Unfortunately, I've not yet cracked the manual. It's in the settings you can get to in the display.
Sorry to see your issue Madman! Looks localised to a specific area of the seat. Hopefully just a bad section, and KiaAu come to the party and fix it.Nappa....
I will indeed. Hope it's a one-off. Other than this I'm besotted with the car.I’m pretty certain you can have your seats replaced under warranty. This is not normal “wear and tear”. Please keep us posted...
