Laughterthe4th
- Mar 21, 2024
does the stinger go into limp mode, if you add a new intake and exhaust? is a tune required for this not to happen if so?
The Stinger can definitely become more sensitive to over-boosting after installing an exhaust and intakes. We had this issue with our GT1 until we installed the JB4 and fixed the air-fuel ratio. Your map, fuel, and temperature can all determine how the car acts upon WOT. We highly recommend the JB4 Tune to help mitigate this issue.does the stinger go into limp mode, if you add a new intake and exhaust? is a tune required for this not to happen if so?
Think of it this way, the ECU uses sensors to 'see' the information it needs for proper operation of the engine. If the data from any of the sensors is out of the safe range, it limits engine operation to safely stop aka limp mode.
Overboost conditions should not be repeatable in stock mode. I have (BMS) intakes and JB4 tune (map 1 or 2) and I live in Canada. I've done launches on cold winter weather and playing in the snow (car drifts amazing with winter tires) and yet the only 1 time I had limp was due to sever misfire on JB4 map2 on 94 octane winter fuel (which is crap).
I'd suggest you do some data logging and check the intake temp and o2 sensor values. I am pretty sure it should not go in limp mode often in cold weather. The ECU can adjust its fuel mixture to always reach the appropriate richness mixtu
I am thinking of getting the velossa bigmouth intake as well as the stillen dual cold air intakes. Do u think it can cause this?The Stinger does go in limp mode but should not do that with intakes or cat back exhaust. As above stated, unless you delete cats or mess with O2 sensors you should be fine.
For a reference, my stinger went in limp mode under WOT because of old Denso spark plugs with JB4. All went away after restarting the car.
Seriously, do a search here. I'm not saying you're wrong, I'm just stating my experience and the experience of what I've read. There are posts upon posts of people with facelift models completely stock getting overboost, particularly in cold weather. As mentioned, it doesn't happen to every single one, but they are definitely more prone to it than pre facelift models. You'll start seeing them in late november or early december (here in the northern hemisphere). All I can say for certain is that when it happens to me, I can reproduce it consistently when the temp is just above freezing and going WOT from a dead stop or creeping, and it always happens between shifts. I can even watch the boost suddenly spike when it happens. Haven't bothered hooking anything up to take readings as I don't have anything that can log.Think of it this way, the ECU uses sensors to 'see' the information it needs for proper operation of the engine. If the data from any of the sensors is out of the safe range, it limits engine operation to safely stop aka limp mode.
I'd suggest you do some data logging and check the intake temp and o2 sensor values. I am pretty sure it should not go in limp mode often in cold weather. The ECU can adjust its fuel mixture to always reach the appropriate richness mixture.
I stated this 2yr's ago and everyone reckoned I just hadn't warmed my car up enough...YES it can happen with just an intake and nothing else... usually on the -22/-23 though
Ask me how I know...
I have a LAP3 coming in next week and then I'll be free to mod once again![]()
