keplaffintech
- Oct 28, 2020
If you turn off traction control and another setting (holding down traction control button for longer than 3 sec.) then it won't shift unless you use the paddles, regardless of the mode.I know that flappy paddles will keep the chosen gear indefinitely when in Sport mode. Can someone try setting the drive mode to 'custom', and Engine/Transmission to 'sport' in the custom mode, and see if the manual mode still sticks? Or will this only happen in Sport mode?
Thanks!
Er, what?? Launch control is traction and stability control OFF and shifting automatically works. What are you saying? Also, in Sport mode the trans reverts to "D" when you come to a complete stop; or you can hold the paddle down and in a couple of seconds the trans will leave manual mode and revert to "D".If you turn off traction control and another setting (holding down traction control button for longer than 3 sec.) then it won't shift unless you use the paddles, regardless of the mode.
Even in sport mode it'll still shift by itself unless you turn off these two options.
for those with the e-shifter, aka gt2 models, they don't have that manual gate..
