Ozstung
5000 Posts Club!
Thanks DC always entertaining.Dash Cam Owners Australia
September 2019 On the Road Compilation
22 Sept 2019
At 11.52 mins is a Kia Stinger Queensland Police car.
22 Sept 2019
Your Welcome.Thanks DC always entertaining.
Never had a flat touch wood, but occasionally get a message on startup saying the starter battery is discharging due to external electronic devices. Check the settings on the power magic pro. See if it’s set to 12v or 12.5v. My installer told me the Stinger needed 12.3v for the smart alternator but my power magic pro is set to 12v/24hrs. Lately I’m lucky if it lasts 12hrs in parking mode, often it’s less before it shuts off. Also check what fuses they tapped for it. The dealership service department should hopefully be able to tell you the best fuses to use. I might double check with mine on Monday when she goes in for service.Oh great flat battery completely dead, got it charging . Looks like I'll disconnect the relatively new Dash cam ,it could be this? I trawled through some Dash cam threads I'm sure I read somewhere @Coast GT Had some initial teething issues. The system is ment to switch off on low battery detection. Rang Kia they said a battery of that age should last a Month without being started. It's only been 5 days.
View attachment 31810a bit of job getting down but here's how mine viewed.
You have to stop having those midnight rendezvous with your wife lolYes 2 weeks and no dramas until now. I'm wondering if when the wife moved the car into the garage she didn't inadvertently leave an internal light on. The battery was completely drained of all charge.
Not my battery the cars battery!You have to stop having those midnight rendezvous with your wife lol
Thought about it but haven’t done it, only get them now and then, it’s weird. Sometimes it’ll run 24hrs in parking mode, others it’ll go 12, sometimes it doesn’t even get to that. It’s definitely the car cutting it off. The guy that installed it seemed to think the 12v should be fine. I’ve never had a flat battery in the 7 months I’ve had the camera in. I don’t need it to record 24hrs, but the next one down is 12, and as I do 12hr shifts and am at work longer than the 12hrs I like it running while I’m parked there so 24 is the only option.Have you tried changing your cut off voltage to 12.5V to see if that eradicates the warning messages? If 12.3V is needed to start the car you don’t want to be running the battery down below that.
Changed to position 5Yep that’s 12.5V and 12 hours. Flip number 5 up to the off position for 6 hours. Realistically the duration shouldn’t matter because it should be cutting out anyway when the voltage drops to 12.5V. Once power is restored it might pay to check how long the last recording on the dash cam ran for, it may help determine whether the PMP is the culprit. You’ve had this for a few weeks now with no dramas though haven’t you?
Changed to position 5. Had to get Horizontal to do it lol.
Wasn't that KIA Sutra, position #4?Sounds like you’ve been reading the Kama Sutra. I know they say pics or it didn’t happen but we’ll make an exception this time.![]()
