3.3TT Creating True Plug-N-Play JB4 Harness (w/Fuel Wires)
This plug and play quick install adapter allows you to install a posi-tap for fuel control tuning without piercing the factory O2 sensor wiring providing a completely reversible connection.
We're waiting for connectors still. Don't have a time frame but can't imagine it will be too long.
No drawback to installing the fuel wires as originally designed other than the pin hole in the o2 sensor harness.
UPDATE
I've sourced the parts to build the harnesses. I can begin offering them for $55 + $8 shipping (USPS Priority Mail Flat Rate Padded Envelope + Delivery Confirmation & Insurance anywhere in the lower 48). International, Alaska, and Hawaii shipping will incur whatever the actual cost of shipping is to your location.
This should cut down on the costs associated with purchasing the individual components.
It'll be a PNP harness with a wire lead from the signal wire (pin 1) that you will connect to the fuel wire using the supplied heat solder sleeve and a heat sleeve once you receive it - the only requirement is a lighter.
Given that i'm using high temperature copper wiring with a heat resistance of 200 degrees celsius (392 degrees fahrenheit), I am considering forgoing wire mesh to keep costs low and expedite the time it takes to make each harness.
If there's interest, I can begin shipping as soon as 7/31. I only ordered enough components for 10. If there's additional interest, i'll order additional materials. I just didn't want to be sitting on a bunch of harnesses without confirmed homes.
@Manaz can you do me a favor and confirm that i've not crossed over to "vendor" territory by offering this solution? Kindly PM me if clarification is needed.
Put me down for a set
UPDATE
So by purchasing this from you, you would send us the completely assembled PNP fuelwire harness? No assembly required on our end, no pin hole, no "this wire should be inserted into that slot" BS, just PNP?...for 65 bucks!?!!
I'll buy a set with the wire mesh.
You’ll still need to connect the 1 wire from each harness to the 1 fuel wire but you simply need a lighter to do it. No pin holes, no posi-taps, no figuring out which wire is pin 1, etc.
You'll have to open PMs up to me. I've got a PM drafted, but it won't send. :)
You should be able to PM me now. Didn’t know I had that feature deactivated.
Put me down as well please!
New owner here... gathering all items before installing the JB4. So put me down for a set as well.
thanks for this.
Been away so I haven’t been able to do my install however still wanted to give @ecko04 a massive shoutout!!
:cool: Thanks for everything!
Cannot wait to install this (and be able to take it off much easier for the dealership visits!)
