I have a CEL and code 0304 reading on the JB4. I attempted WOT with map2 and the whole engine lost power. I limped home and turned the car off. Turned it back on and it ran normally. A week or so later, I got the CEL with the code 0304 while about 75% or less throttle merging onto a highway. Engine seems to misfire at any throttle above 40%. I thought the issue was with the plug on cylinder 4, so I removed it, confirmed .22 gap, plug was not damaged, and reinstalled. Same issue. Where do I go from here? After I installed everything in the BMS performance package, it was running great. I haven't tapped the fuel lines into the JB4 yet, could that be the issue? I don't go WOT often at all, in fact it was only to test my 0-60 . Been running 93 octane top tier.
Interface won't let my PM Terry@BMS, so I figured I'd ask the wider forum.
