Bron
- Oct 15, 2023
This is great advice, thank you! I think Andrei and I have different problems but this is definitely something both of us can try. Do you really need to take the wheel off to get to the sway bar end link?The strut top mount can definitely be replaced. I actually bought a LH one a while back thinking one of ours was bad. Turned out it wasn't and we replaced the whole strut with coilovers sooner after, so I still have this brand new LH side one, if anybody needs one: GENUINE Front Suspension Strut Mount LH for Genesis G70 Stinger 18-22 ,1Pcs | eBay
If I were you, I would do some tests to see if you can isolate the creaking to a particular location. Start by looking for a speed bump that you can roll over only on one side of the car. A block of 2x4 makes an excellent speed bump. Listen to see if you can tell any difference between the two sides. Next, remove the front wheels and disconnect the anti-roll bar end links. Takes two nuts. Repeat the same speed bump test. IF the creaking is gone, then you know it's likely the anti-roll bars. Otherwise, by decoupling the two front suspensions, you should be able to tell which side - or both - are creaking. Have a person stand next to the speed bump, while you slowly roll over it. Might be easier to hear it, than you sitting in the car, even with the windows down.
This video at 2:20 is exactly what I'm hearing now with the thud. The strut mount before it was replaced was this sound but louder. The video is all about sway bar links. But I just spoke to the dealer and they claim they checked the links. So I have no f****ing idea now.
