Bushing bad after 60k Miles?
I'm having a noise on my left side wen turning the wheel that way. If I'm pulling out of a parking spot nd turn my wheel left I get a noise that sounds like a door open nd closing smh. My question is I see I have 2 control arms. Which one did u change? The straight one or the one that's curved a little bit.
The curved one.
I wouldn't describe the noise I had as a squeaky door opening and closing though.
Creaking, yep that sounds like it. I've commented on a few other posts that sounded like the exact same issue. I'm too new to the forums and Stingers to say this isn't an isolated problem, but I've commented on at least 3 other posts with the same issue.
Lower control arm replacement fixed it for me.
Which one did you replace the straight or curved one?
I've only had my Stinger for about 5 months. Bought it with 57k Miles. A month after buying it, my front suspension seems to have given up on life. It start with a loud creaking sound, like metal decompressing, when I would reverse with the wheel turned and pull forward and turning the wheel the other direction. This was fixed by the dealer replacing the lower control arms, despite them saying the control arm bushings looked fine. At the same time this noise started, or before the fix, the passenger front wheel started making a deep thunk sound when going over even small bumps in the road. It was most apparent when the tire was suddenly dropping. This noise was fixed by the dealer replacing the upper strut mounts, again, even though they said the mounts looked fine.
All though the thunk is much better after the replacement mounts. I am still getting a thunk and the entire suspension feels loose when I go over small imperfections in the road. In my non mechanic opinion, it feels like all of the bushing all bad. I've had some old jeeps with completely shot bushings and this feels the same as when they would go over a bump, but my steering feels tight.
My question for those who are way smarter then me is, bushing shouldn't go bad at 60k miles right? And the follow up question is, if the bushing are all bad but not visually bad, is there something else causing them to fail suddenly?
The dealer has had my car for over 20 hours trying to diagnosis the issue and I've had an independent mechanic check the suspension and say it appeared fine.
Which control arm did they change? The straight or the curved one?
Can this kit be used in lieu of purchasing new control arms??
It only replaces the large end of the curved control arm. So, you'd be okay if the small end bushing is still in good shape. Otherwise, no.
Which exact OEM part this bushing kit replaces?
60,000 miles is a lot. That's 100,000kms in Australia and thats when people seriously think about changing a car out for a new one.
That's 10 years of average driving and 5 years of heavy driving. You drive over speed humps and drive into corners like a stock car and bushes are going to be split, compressed, stretched, broken after 60,000 miles.....
I'm the driver that drives even slower than crawling over all them horrible speed bumps and humps everywhere. No wonder so many experience suspension damage.
Fair enough. I berate the missus when she does it. My Stingers will be brand new the day i sell them
Yup less and less mechanical sympathy nowadays within the general populace nowadays.
Is there any difference in ride quality or handling?
Each driver's perception of NVH is different, so my describing how I perceive the difference doesn't always translate well to another driver's own perception. Same goes for handling.
Does a harder-durometer polyurethane bushing improve handling precision and stiffen ride quality? Potentially yes and yes. Would you notice the difference? Only you can answer that.
Probably not worth price and time installing it.
Just had a starter fail 6 weeks ago on our 21 G70 3.3T w/ 48k miles. When it was getting replaced they did a full check on the car and found leaking timing cover seals and both front control arm bushings that were cracking. They repaired all under warranty and replaced the entire control arms rather than just the bushings. Hopefully they'll hold up longer than another 48k miles, but at least @Volfy linked the replacement bushings should I need them down the road.
A lot depends on the usage case. If you impose high dynamic loads on your Stinger under heavy braking/cornering, where those soft bushings allow the front wheels to be pushed rearward, altering suspension geometry precisely when you least want it to, then it might be worth it.
stinger-2-webp.84967
I have the Superpro castor bushes in mine so I can adjust the castor and eradicate the pulling left that plagued my car since I lowered it..
However my R/H strut has a clunk in anything but Sports mode and I have done a bit of track driving since it started but the car drives fine regardless...
KIA want $2100 for 1 x strut and $660 labour to fit it !
No warranty because I have Eibach lowered springs and Aftermarket swaybars...
They haven't blamed my non factory suspension for the sunroof rattle tho' and at least they are going to fix that for me !
Damn, could probably go air struts for that price!
Full set of Gecko coil overs and the canceller/ blocker for the electronic struts. 😉
