brianwithnoy
- Nov 12, 2020
I've installed and been running the Borla Exhaust for about a week and I've noticed a slight 'issue' with it...
Check out the two photos below:
Right muffler
Left muffler
Notice how on the right muffler, the right most tailpipe, and on the left muffler, on the leftmost tailpipe, each of those respective tailpipes seem to be slanted downward? I think it's very strange - the photos don't really do justice but trust me, when you see it in person it's clear that those are definitely slanted downward. I am under the assumption that all 4 tailpipes should be centered in the exhaust tips, or if not at least close enough to be centered and not immediately notice a downward slant.
Also, on the left muffler on the left most tailpipe (the slanted down one) it does a very peculiar thing when the exhaust has come up to temp. The left side of the muffler seems to come down a bit under temperature to the point where the left most tailpipe actually hits the exhaust tip - and under throttle the tailpipe vibrates against the exhaust tip, causing a very annoying rattling noise (not talking about drone, but specifically a metal-on-metal kind of sounding noise under throttle)
I did install the exhaust myself but upon seeing this, I went under the car twice to check all nuts, bolts, hangars, alignment, etc... nothing seems out of place/loose/misaligned regarding the install. The exhaust is rock solid in its place with very little movement to give.
Has anyone else who has/had the Borla exhaust have/had this issue??? For paying over $1000 for this, I didn't expect this to be something I'd have to look into. If this isn't what the Borla exhaust should be looking like, it almost looks like it was a poor welding job/craftsmanship done over at the factory... Curious to see if anyone's faced something like this.
Right muffler
Left muffler
