fourthvictor
I recently purchased the BMS Intercooler and upon opening the box I noticed some metal flakes on the cold (outlet) pipe of the intercooler. I contacted BMS and was told “Where do you see it? Maybe you can vacuum it or us airblower. I don’t see an issue in. The photo.” I followed their advice and did blow out what I could see using an air compressor. After that, I rinsed it with water, blew it out again with the air compressor, and let it dry out. It’s currently sitting in my garage. I’m slightly apprehensive about installing it due to the metal flakes (even though I think I removed most, if not all of them). I’m very tempted to return it, but at the same time I’m not sure if such small flakes would do any damage or if there is even any flakes remaining. What do you all recommend? I’ve attached pictures of the outlet and inlet pipes. I didn’t really see any metal flakes on the inlet pipe fins.
