I'm running Velossa
snorkels + stock air box + upgraded panel filters. I can tell you that the air duct assembly is ridiculously restrictive, and when I removed it I was perplexed how Kia could design an air intake path so convoluted.
If the AFE is pulling 100% of its intake air through those air ducts (and doesn't have any other path to intake air) then I would definitely remove the air ducts. There is no downside, and it's free other than an hour or two of effort to drop and re-install the bumper.
Hard to say if you will feel a power increase however. But, with the stock air boxes in place, higher flow panel filters, and the
snorkels in place I did notice a mid-upper power increase over completely stock.. That was with a JB4 on Map2. I now run the same setup on map5 e30 and can hold 20 lbs of boost to 6000rpms.
The
snorkels do a nice job of "ramming" air into the intake at higher speeds (like 3rd and 4th gear). On my Veloster N I noticed that got an extra 1.5 lbs of boost in the upper RPMs at higher speeds with the JB4 after I installed the
Snorkels. I don't see the same thing with the Stinger, but it in general holds boost better into the upper RPMs especially with the waste gate adapters installed and adjusted to my liking.
Personally I'd run the
snorkels with the AFE intake. They're fairly cheap and you'll already have the bumper off anyway to remove those stupid air ducts.
