Any dynos for ram air systems?
unpopular opinion - most of the intakes for the Stinger, including DIY are ram air
It is likely his definition of "ram" air is a direct, front-facing opening that allows higher speeds to literally RAM air into the air filter (such as a hood scoop routed into the air filter/box as you find on Firebirds). Velossa snorkels are an example of ram air as well as JT snorkels for their intake. An open box is not "ram" air to most people even if it allows more air to be drawn in.
Thats correct.
Does anyone have any first hand experience with the snorkels, or dynos even?
Just curious if anyone has done any testing to see whether ram air systems provide better airflow (hp bump) or not.
If you have them installed, please chime in :)
The car is on a stationary dyno, how do you expect to see HP increases without a wind tunnel that can simulate the increase in airflow from an increase in speed?
Gonna be hard to replicate any impact on a Dyno. The fan is rammed right up against the bumper by default.
Then I guess at this point I'm waiting for someone that has them installed to tell me what they think about them :thumbup:
There was a discussion in another thread and the general consensus that the snorkels (i.e., Velossa) have no impact on performance, at least in terms of power. Perhaps they increase airflow, but this hasn’t been shown. Despite the snorkels being out for a year they aren’t back by any quantitative data. Qualitatively, owners of said snorkels like them.
See thread above. Page 2 specifically.
My post specifically referenced power. As I stated previously, they may well flow more air, but they don’t influence power. However, folks that have them are happy.
I believe the OP was looking specifically for dyno numbers, which would lead me to believe he’s looking for adding power, which until there’s more information, the snorkels do not accomplish.
Once again, I’m not saying the snorkels don’t work. It’s just important to consider what they were designed to do — which isn’t to make more power, but rather to be more efficient with air flow, which a dyno will not necessarily reflect.
They flow cooler air, which correlates to more power. It’s likely not 10hp but cooler air will equal more power.
It’s not a causation. There are a great many factors that influence, or negate, cooler air having an impact on power so while there may be a correlation it is not an, if I do x, y happens. I am positive that is Velossa Tech found a significant, or even notable, power difference they would have included that in their marketing material. Once again, it’s not designed to create power — which their posts in your thread state.
While not an apples to apples comparison, upgrading an intercooler lowers air charge temps, but doesn’t necessary equate to more power in and of itself.
I’ll say this though, if I could fit the snorkels on my car, I would have them. They just don’t fit with the gigantic IC I have and the IC may negate the benefit of them anyway — but they look cool.
