So I think you just confirmed that you don't have an ecu tune. To fix your issue they must have flashed you back to stock.
The biggest problem Tim was the Crappy gas here in BC Canada the Tune per day was mild yes ,
and if you looked at the 2 runs on the sheet , one chipped on top of their PT tune , and the other run just with the tune only, out of the 7 runs we did on the May 13 2020
THe Bottom line is the problem with Limp has now been solved !!
Johns Stage one TOrk Tune most likely would be stronger than I have now , but then you would know better than most , as you use TOrk stage 2 tune with a JB4 piggy to run Other function s WMI . What I have right now is working perfectly with one push on the RC app chip is off , only PT tune , press again and I hit a solid 409 Awd whp with 508 ftlbs torque, I only have one car , so it is good where it is setup at now for myself
I Had terrible time trying to get everything working , and find that our gas quality is not up to the standards of the US gas , so at the end of the day this is what I will have to settle for
Everything is with safety parameters and and as I like to think numbers don’t lie
but on that note my tune should not have been rated In any way a Stage 2 as TOrk s stage 1 as you have told me before would give approximately 420 Awd whp with all my
mods , Into personal thanks everyone for their input on all the minor issues that I have had over the past two years
I have not and will put others Tuners products down for any reason
At over 60 years old I am never scared to learn things, I will leave it at that !!! Safe driving everyone
