WildBill
It's literally 10 minutes of disassembly to check. Its just what you need to do...
-Remove the rear carpet, floor piece, and the molded piece over the spare tire.
-Flat head screwdriver to carefully pop the two push pins on the rear trim piece, Carefully pull the trim piece up. I believe there are 4 clips that hold it in.
-Remove 3 or 4 screws that hold the right side lining piece in, one of them is behind a plastic plug on top.
-Working from the trunk opening to the top of the seats pop the clips holding the right trunk lining in.
-Voila, a clear view.
-I'm thinking it will be up above the rear fuse box hiding on the back side of a bracket.
If not, I'm sorry. That is where I legitimately thought it would likely be.
