3.3TT 18 GT2 Logs
timing is a little off but not the end of the world bad. you could reset the ecu, pull the negative battery terminal for 15 minutes. Then drive for a bit and run some new logs. the ecu may be compensating based on old data and the reset will clean it up... I agree, if you can find good gas, and the plugs are correct, you should be running map 2.
Question if i bought a stinger gt2 pre owned with 30k miles have everything done too it that i should but still pulling timing in map 2 and 3 would it probably fix that issue also i am running a perfect e30 mix
Yes, it very well could. Also, have you sent Terry your logs for review? He might say they look fine. Anyway, resetting is easy and always worth a shot.
I have and sent him previous logs and he said they were fine but they didnt have huge deviations in ign 2-6 like it does in a spot or two now
But i just sent him new logs on map 2 and will see where it goes. Hopefully its running properly i love the way map 2 pulls
