StingertimeNC
1000 Posts Club!
timing is a little off but not the end of the world bad. you could reset the ecu, pull the negative battery terminal for 15 minutes. Then drive for a bit and run some new logs. the ecu may be compensating based on old data and the reset will clean it up... I agree, if you can find good gas, and the plugs are correct, you should be running map 2.
