Description
THIS POST <– (click there) in our forum community is even easier than the video below…
INSTALLATION INSTRUCTIONS:
$49.95
Both sides included and fit all 2018+ Stingers. Also known as “side marker delete”. These body-color painted rear reflectors use OEM parts and OEM paint! They’re for off-road use only because, you know, reflectors are there for safety. In any event, they’re painted using the OEM KIA paint.
To install, (most detailed instructions below) you need to remove the inner lining (there are four 10mm bolts you need to remove after you take out the floor cover and spare tire cover) and tail light. Then there are three screws holding each side in. After you remove the standard reflectors, install the new body-color painted pieces…
| Weight | 8 oz |
| Dimensions | 3 × 1 × .5 in |
| Rear Side Reflectors | Ascot Green, Aurora Black, Carbon Fiber, Micro Blue, Panthera Metal, Silky Silver, Snow White Pearl, Ghost Grey/Ceramic Silver |
