Description
By purchasing this item you agree to the Terms and Conditions
$199.00
Don’t let weak and unresponsive factory gas pedal mapping ruin your driving experience!
Works for BOTH the 3.3TT and 2.0T Stinger! This plug and play tuner attaches to your gas pedal allowing you to remap and improve throttle response. Toggle between stock, stage 1, stage 2, and stage 3 curves on the fly and even fine tune each mode using simple up or down adjustment buttons on the device. The BMS Pedal Tuner Installs and removes in minutes and is fully independent from and compatible with other modifications including the JB4.
Out of stock
Weight | 10 oz |
Dimensions | 9 × 7 × 1 in |
