Posted elsewhere, I mentioned I recently purchased a new GT about 6 weeks ago.
After putting a few hundred clicks on the clock, I noticed an exterior metallic rattle which could only be heard while driving with a window down and when travelling over bumps at a range of speed 30 - 60 kms/hr. The noise sounded like a set of keys or Tamborine rattling from underneath the car. Whilst only a subtle rattle, it was EXTREMELY IRRITATING, particularly considering the car was only a few weeks old and given I was hoping the bulid quality would be better than a Ford Festiva. Off to the dealer service department for diagnosis and fix.
First visit to the dealer: invoice cited “2 exhaust heat sheilds found to be incorrectly installed, overlapping and causing rattle. Vehicle road tested and noise found to be no longer present”. I drove the car out of the dealership and could hear the rattle over the first set of bumps.. I quickly dreaded where this journey was headed so I asked a friend of mine (veteran diesel mechanic with decades of experience) to come for a ride and help diagnose. His first suggestion was to hover the brake pedal while driving and see if the noise was still present over bumps. After about an hour of road testing, we determined the rattle could not be replicated while the brakes were being applied - obviously a brake related issue and likely to be rattling pads. We were further able to determine it was rear brake related and probably only coming from the driver’s side.
Second visit to dealer: advised them it was rear driver’s side brake related. Sadly they didn’t listen to what I told them and instead literally started taking the car apart.. They removed the underbody trays and started bending exhaust heat shields.. After running out of time within business hours they called it a day and asked me to drop it back in so they could start pulling the wheel arch guards out..
Third visit to dealer: I’m pretty jacked by this point having learned what they got up to the previous day. So upon dropping the car off I refused to leave without talking to the workshop foreman. I spoke to him and re-emphasised the brake hypothesis and our amateur testing results. My diesel mate said an old trick is to place a dab of silicon behind the pad to “fill” the void and stop the rattle which I relayed to the foreman. The foreman agreed they would finally focus on the brakes so they took the rear brakes apart and applied some “anti-rattle spray” to the back of the rear brake pads.
I picked the car up hoping third time, $65000 car half dismantled lucky..
Voila, NO MORE RATTLE! My diesel mechanic mate was right. It was definitely the rear pads. Not sure what Brembo would have to say about this..? I’m told Brembo’s are fitted to Ferraris..
I hope this post is helpful for others who may have had this issue, saving repeat trips to a dealer and having your new car pulled apart.. If you have had the same issue, please comment accordingly and if there are a few responses I will email Kia Australia to advise.
