So, the Stinger has a turbo timer.
weew
I don't know if anyone else noticed this or not. Apparently the Stinger has a built-in turbo timer or something like it. It only activates after a lot of hard driving though.
In my case, it was a hot day (close to 30 C), drove straight up a mountain to go for a hike. I was kinda stepping on it, having fun with the mountain curves, so the turbos were definitely being worked hard.
After parking the car, I noticed the radiator fans were still going at full blast. I almost thought I forgot to turn off the engine, so I double checked. Car was definitely off. The fans only turned off after about 4-5 minutes.
Since the car's never done that before, I figure it must have only done it because of the hard driving I did just prior to parking.
Many cars do that - run the fans after being shut down.
You really should not shut down the engine immediately after hard driving. The turbos are especially hard on oil, which stops circulating when the engine is not running.
When i get home I sit for two minutes at idle before shutting off.
Best thing to do is similar to a cool down lap, especially after pushing the car. Take it slow but keep moving, allows the air flow to cool the turbos and brakes down faster. I do this when I get close to home. Lots of benefits like not pissing off neighbors or speeding in a residential.
@eflyguy is right. The turbo shafts are directly in the red-hot exhaust stream on one end and are equally red-hot. The reason that all turbo engines require fully synthetic oil (GF-4 or better) is that synthetic oil does not cook into a sludge at insane temperatures and freeze the turbo shaft and bearings like regular oil does. Even so, it is good practice to let the engine and exhaust cool down a bit before shutting the engine off after a hard run. The electric cooling fans are helping cool the exhaust manifold down which is why they run for a while. It is also important to change oil at designated intervals to replace old oil with new oil and incorporated additives that help keep things clean.
my grand national used to do that all the time
Good reminder! "Drive last road sedately. Cool down the car!"
Welcome to 1951
Welcome to 1951
Better oil than 1951 allows ignorant drivers to potentially abuse their engines without the problems of yesteryear. 6,000 mile changes with full synthetic oil is enough for Kia to warranty the engine and turbos for 10 years/100,000 miles (in the U.S., anyway.) That doesn't mean you can totally ignore the inherent problems with exhaust gas temperature as high as 1,400°F. Trust your choice of oil, sure, but why run so close to disaster? I keep my cars for 150,000 to 200,000 miles, far beyond factory guarantees. I guess if you trade cars every couple of years, who cares? Pass the problem along to some used car buyer.
sorry, but diesel engines using dino juice for decades with their turbos had zero instances,using conventional oil, yes synthetic is better but conventional oil works on any engine if changed regularly.the only reason sludge is created is from lower oil temperatures.....not higher temps.
Absolutely correct for diesel. mldavis Comments didn't call it out, but they apply to gasoline engines. Diesels are completely different, diesel exhaust temps are MASSIVELY lower than gasoline, so as much as the mechanical design of the turbos are similar, they are not subject to the problems of "cooking" oil when shut down.
Not that it also takes some effort to produce a useful catalytic converter system for diesel, because the exhaust is so much cooler (and cats use exhaust temp to light off the chemical process that reduces the noxious stuff in the fumes)
Edit - had to add - this is why turbo has been so prevalent in diesel engines for so long. It's a VERY efficient and reliable way to increase combustion volume, but it doesn't translate to gasoline easily. Go look for super/hyper-cars that have turbos. There aren't, and never have been, many.
Edit #2 - sorry! So Synthetics can be engineered to be less prone to damage from high heat, but there's currently no materials technology able prevent it completely at the temperatures seen in an exhaust system of a gasoline-fueled engine. If you run 12.6 at the strip, then park and shut down the engine, you will cook the oil, period, no matter what kind it is. It may only be a little, but there will be deposits than can cause wear, or limit flow, and over time, the engine will be ruined.
Edit #3 - SORRRY!!!! But thinking about it, most people don't realize just how much of a difference a seemingly small difference in some process can make. In this case - exhaust temps, and the effect on oil. Anyone who cooks, however, knows that there is a fine line between perfection, or absolute ruin, of ingredients over a stove - sugar (candy), chocolate, eggs, even - to some degree - more forgiving items like steak or fish. You can totally destroy them if you don't heat (cook) within a certain set of parameters.
Oil is the same. Even synthetic is an engineered organic molecule. You may think the seemingly insignificant difference should not matter, but it does. As you approach a limit, chemical composition breaks down quicker than most people realize, and if you cross a line, you can't just back off and expect it to return to status quo. These processes - cooking, or lubricating - have one-way doors to total failure. They can happen in the blink of an eye, and in your engine, all may seem well, but there could be terminal damage being done as a result of a simple, short overheat condition. It will just take time to show up - like selling spoiled candy in a store for a few weeks. Only after you get enough complaints will you realize a mistake was made....
I'll buy that, as for sludge? c'mon.....heat would actually eliminate the problem....imo.
No, it won't. "Sludge" is a result of excessive heating, breaking down the fluid (oil), exactly like how you can heat a tasty liquid like wine or juices from cooking into a more concentrated, thicker syrup over heat.
nope , not buying excessive temps cause sludge..........lack of oil changes and common contaminates (with regular heat cycles) causes' sludge.again imho.
Just my two cents... conventional motor oil oxidizes with high temperatures. Combine the oxidation with contaminates over time and sludge is created. Frequent oil changes significantly reduce this. Synthetic oils do not oxidize under extreme heat. Even with contaminates, sludge is not going to form. Synthetic oils, by their chemical composition, don’t oxidize. It’s chemistry! :-)
oxidation.....I don't know. But oil breakdown on a molecular level ...add some debris....might equal sludge.....
Oxidation - Simple English Wikipedia, the free encyclopedia
Oxidation is the opposite of reduction. A reduction-reaction always comes together with an oxidation-reaction. Oxidation and reduction together are called redox (reduction and oxidation). Oxygen does not have to be present in a reaction, for it to be a redox-reaction. Oxidation is the loss of electrons.
