3.3TT Declined to do Alignment
I dont understand these shops. The machine doesn't align anything automatically, all it does is provide parameters and readings based on adjustments.
All the toolbags have to do is read the sheet and adjust until they meet your sheet or get it best effort. Its simple. But yes, camber is usually not adjustable without adjustable arms.
It took me longer to find a place that could accommodate the lowered height of the car then to find a place willing to do it. Luckily, I found this place called Bruce Bros who had their machine built into the floor, which is awesome.
They used my sheet and all is well. They will receive my return business.
Which specs they used, the "normal or high suspensión type"?. Thank you
Pretty sure the "High" is for AWD and "normal" was for RWD. I used the "high" setting on my GT2 AWD.
Curious for all who have had shops adjust alignment what are settings you achieved with eibach springs?
OEM-ish specs with room to spare for adjustment.
Had Eibach springs installed and a wheel alignment. My suspension guy told me to stop reading the forum:laugh::laugh::laugh:.
Where'd you go?
