KLR STINGER
- Mar 31, 2018
Hi Folks,
After months of waiting, I received my Eibach pro-kit springs and sway bars a week ago, and got around to installing this weekend. Some install tips are below, but in quick summary..DO IT. Completely transforms the car. Car rides better than stock. All the unsettled behavior mid corner from the rear is gone. No additional noise or harshness. Turn in is instant, with no roll. I've done springs and says on many cars, and this is the most trans formative so far. I'm going to play with swaybar settings once I get some adjustable end links, but I'm rear rear firm, front soft right now.
Installation notes:
Rear sway
Degree of difficulty: 4
Tips: the only real issue is the one inboard, driver side nut. It's pretty well blocked by the fuel tank filler hose. I had to use a flex head gear wrench to get underneath the hose and have any room to swing it, leaving little leverage, but steadily wrenching it came off. After that the other 2 bolts and nut come out easy and it slides out the driver side.
Rear Springs
Degree of difficulty: 2
Tips: These come out no problem. Undue the lower shock mount and spindle from the lower control arm, and out they come. Use a jack to compress once new ones are in and bolt back up. Easy Peasy
Front Sway
Degree of difficulty: 3
Tips: Easier than the front. Removing harness from power steering. Remove end link nuts. ( a hollow socket set helps if you dont have a high speed impact). Then remove sway bar brackets to subframe and it drops right out.
Front Spring
Degree of difficulty: f*ck you Kia
Tips: These sucked. By far the most tedious spring install I've done. On an AWD literally every suspension component has to come off the spindle. While Annoying, and time consuming, thats not the shitty part. There are three compression fit ball joints per side that need to be removed. These ride in steel inserts inside the alum spindle. They were a huge PITA to pop free from spindle. Now had I bothered to get the OEM ball joint separator tool, probably would not have been that bad. But without it was a hell of a job to break them free. Improvised a small 3 jaw puller, and repeated banging till free. After freeing those, getting out strut assembly was easy. I have a floor standing spring compressor which makes the actual spring sway a breeze.
Don't even think of doing this without the right separator tool. Go to hyundai/kia and get one. Pickling fork style will not work. Alternatively
Something like this should work: 204-592 Lower Arm Ball Joint Separator Tool
All in all well worth it though!
Installation notes:
Rear sway
Rear Springs
Front Sway
Front Spring
