Did anyone notice that top speed was obtained in 6th gear. Looks like there is not enough power to pull greater speeds from 7th and 8th unless they are governed.I came across Road and Track's offical performance review on the GT and thought I'd share the performance report. It's a nice break down on all the critical performance data.
Road and Track is guessing that is what will happen. I wonder if anyone has tried.Did anyone notice that top speed was obtained in 6th gear. Looks like there is not enough power to pull greater speeds from 7th and 8th unless they are governed.
All three are overdrive ratios.7th and 8th are probably overdrive.
I think that's because most of the information on that data sheet was taken directly from Kia and written up on a pretty little all-in-one sheet with R&Ts name on it.
I'll agree with the last part of your statement but back in the 50's, 60's overdrive meant a gear ratio that was higher than 1 to 1. Had nothing to due with top speed. 5th gear is 1 to 1 in the Stinger and 6,7,8 is higher than 1 to 1. I believe it's no longer called overdrive because with all the gears in the current trans, there's more that 1 gear higher than 1 to 1.The very definition of "overdrive" is gears that will not allow a vehicle to reach top speed. They're there to allow cruising at lower RPM.
With the early development of cars and the almost universal rear-wheel drive layout, the final drive (i.e. rear axle) ratio for fast cars was chosen to give the ratio for maximum speed. The gearbox was designed so that, for efficiency, the fastest ratio would be a "direct-drive" or "straight-through" 1:1 ratio, avoiding frictional losses in the gears. Achieving an overdriven ratio for cruising thus required a gearbox ratio even higher than this, i.e. the gearbox output shaft rotating faster than the engine. The propeller shaft linking gearbox and rear axle is thus overdriven, and a transmission capable of doing this became termed an "overdrive" transmission.
I don't understand your comment, all the difference? In what?I had a 1967 Volvo 122S 4 Speed that had overdrive. It made all the difference.
I hit 155 MPH in 7th gear; and backed off; it was still pulling strongly. In fact I did all my accelerating from c. 75 to 155 in that one gear. I wasn't in any hurry to get there! But it was floored the whole time. The road was, of course, perfectly straight and only had small rises and dips in it (Hwy 95, heading out of Oregon).Did anyone notice that top speed was obtained in 6th gear. Looks like there is not enough power to pull greater speeds from 7th and 8th unless they are governed.
Did you read about the tire that gave way at 70 mph?I hit 155 MPH in 7th gear; and backed off; it was still pulling strongly. In fact I did all my accelerating from c. 75 to 155 in that one gear. I wasn't in any hurry to get there! But it was floored the whole time. The road was, of course, perfectly straight and only had small rises and dips in it (Hwy 95, heading out of Oregon).
