Tubi Exhaust finally arrives
That's the plan but no date has been set.
Have you had it installed yet?
If so how are you liking it?
Yep. I got it installed Friday and so far I love it. Worth every penny.
I would but I don't have the recording equipment to do it justice.
Just use the phone no need for recording equipment.
I did the sound was too low to record with phone when opening values. I'll put it up later but it doesn't do it justice.
With open valves is there drone while drivving.
With valves closed is it similar to stock in sound level?
I drive in sports mode on the exhaust pand there is some drone especially at rpms around 2000 when the valves are open. But the valves close 10 seconds after hard acceleration. With the values close it is only slightly louder then stock on the inside. But on the outside it just has a much deeper tone all around.
