Fl stingergt
- Mar 1, 2018
This engine is so easy to get big hp and torque gains for around 2 grand. Almost 50 hp 75lb torque extra
We are already over 120 WHP gains with our new tune. Posting soon.This engine is so easy to get big hp and torque gains for around 2 grand. Almost 50 hp 75lb torque extra
I wouldn't call a piggy back a tune... well, maybe a "box tune"Cheaper than that. I paid $220 for a tune, $1000 for exhaust, and $100 for drop in filters. $1320 total.
No dyno numbers to confirm but I figure those three have to be good for over 60 hp. My uneducated guess would be >50 for the tune, >10 for the exhaust, and <5 for the drop in filters.
I tried running the numbers on this picture in Honeywell’s website but nothing. Anyone know if this is a T3 turbo or different size? Thinking of buying a couple turbo blankets.
I have no idea what any of that means but thank you!The stock turbo is a Garrett gt17 series with hyundai specific exhaust housing with integrated manifold to the head. You will not find anything that fits this.
There is independent research that it keeps other components cooler and reduces turbo lag and increases boost by keeping the warm side of the turbo warm and the cool side cool.Just out of curiosity why do you think a turbo blanket will help in this application?
I'm quite glad KLR Stinger explained what he did in this thread. I've been wondering myself about using that third cylinder per side on a moderately larger turbo, but he is explaining why the logistics of that require major modifications.
I would love to see, however, the bold pathfinders take this step: larger intercooler, moderately larger turbo, fed by all three cylinders per side to minimize turbo lag on said larger turbo (again, moderately, as one that's too big ruins driveability). I would think that's good for 600-650HP. What transmission upgrades are needed (or internal engine components, even) to accommodate this is where my mind is really sitting.
When/if a 600HP Stinger GT is a comfortable daily driver reality is when I'll be all up in my Stinger's nuts swapping this stuff out![]()
There is no "spare cylinder" to use for another turbo. The engine has an exhaust manifold intergrated into the cylinder head. All three cylinders per side are merged to an exhaust port that feeds the exhaust turbine of the turbo.
Got a link to this research? I’d be interested to see what kind of data they are seeing on small turbo applications with mainly stock components.
Interesting. I had heard that only two cylinders on each side drive the turbos.There is no "spare cylinder" to use for another turbo. The engine has an exhaust manifold intergrated into the cylinder head. All three cylinders per side are merged to an exhaust port that feeds the exhaust turbine of the turbo.
My lack of knowledge on the Lambda II engine and the turbo configuration doesn't mean I don't understand concepts, lolHere's an early render of a 3.3 T-GDi head with the integrated manifold and a picture of the turbocharger assembly which shows what I mean. Yes I know the bolt pattern doesn't match but you get the idea.
View attachment 8817 View attachment 8818
