Ucinn
1000 Posts Club!
It has been this way since the first knock sensor was put on an engine.
No, the manual has been updated as per the conversation above. And if you read the rest of what I wrote, you would know what's up.
Go ahead and contact KIA and ask then to confirm the HP/torque numbers are achieved with regular (87 octane). First, laugh that they won't be able to give you an answer straight away (why?!?!). Then, tell us what the eventual answer is.
If you really want to bang your head into the wall, ask what the HP and torque numbers are at the common octane levels (87, 89, 91, 93).
Marc, that wasn't intended for you, your post got snuck in between my two. Sorry for the mix up.
That depends on your choice of refueling stations. Costco (at least around here, Utah) does not have "midgrade", only regular (85 octane) and premium (91 octane). So, as already pointed out by our Roosevelt Ut friend, @BlaydeX15 out here we don't have the option. Our "midgrade" when offered is barely 87 octane.I guess I don't understand the confusion over this.
As has been repeated in this thread, Kia RECOMMENDS 91 octane (key word "Recommends"), and states that you "could" lose some engine power if you use gasoline of less than 91 octane. That probably should read "will" lose some power, since retarding timing will result in some loss of power. But the loss is probably not enough for most people to notice in normal driving.
The point remains that the use of 87 octane gas won't hurt your car, and if you want to save some money, use Regular gas. If not, use Premium or even Mid-Grade.
It's up to you!
I suppose you could make your own mid grade.... 10 gals of regular + 10 gals of premium.That depends on your choice of refueling stations. Costco (at least around here, Utah) does not have "midgrade", only regular (85 octane) and premium (91 octane). So, as already pointed out by our Roosevelt Ut friend, @BlaydeX15 out here we don't have the option. Our "midgrade" when offered is barely 87 octane.
I suppose so, too. Isn't mixing gas a bit like running with scissors or juggling swords?
I think trying to put 20 gallons in the Stinger would lead to quite a mess!I suppose you could make your own mid grade.... 10 gals of regular + 10 gals of premium.![]()
I'm sure everyone gets the drift, if you normally put in 14 gal on fill up, put the first 7 in using reg. and top it off with prem.I think trying to put 20 gallons in the Stinger would lead to quite a mess!
No worries, that was what we call a joke.I'm sure everyone gets the drift, if you normally put in 14 gal on fill up, put the first 7 in using reg. and top it off with prem.
I think it would be two separate purchases. Would take a little extra time.No worries, that was what we call a joke.
As a practical matter though, having never done it myself, do gas pumps typically let you just switch fuel grades on the fly or do you have to complete the transaction then swipe your credit card and put your zip code in all over again?
