Parked it in the GT1 Polebarn last night. After all it's a lease and 12K miles a year can come quick. Drove the 03 accord to work today , that's my beater..
How do you operate it? Do you need a separate remote?
Came with two remotes and also operates from the car's fob. Hit the lock button and then within 3 seconds hit either the hatch pop or panic button to start. Hit either the trunk pop or panic button to shutoff when running (the car honks when you shut it off this way, it shuts off without honking if you open a door.)
It is not difficult to install, but it is time-consuming and a pain.
NY...That is bad ass. Looks awesome, where from. Whars on bottom of light?
I tried fecklessly to sand down the touch up pen "boogers" on my car, and succeeded in knocking them down, at the cost of turning the Silky Silver touch ups dark!? Grrr! I haven't got a solution yet.
You may have removed the clear from them. That could give the effect of being darker.
Does your pen have a paint end and a clear end? If so add some clear to it, give it a week or so to cure, then hit with some rubbing compound and then polishing compound.
I started using this tool for touch-ups and it works nicely...puts only a little bit of paint at a time instead of globbing like the Kia touch-up pen does. I bought it when it was cheaper than this though: https://www.amazon.com/gp/product/B004YZXV8U/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
There wasn't any "clear" to begin with. This touch up paint came at the end of the fibrous tip of the Kia touch up "pen". As @StingerGT68 noted, it lays down too much paint for really small jobs. This requires wet sanding, very carefully, to avoid what you are addressing: rubbing/sanding through the surrounding clear coat. I'm confident that I have only lightly crazed the clear coat, which a rubbing compound works to restore after the sanding. What I need is a way to make the sanded touch up paint match the surrounding Silky Silver, instead of turning dark. Thanks for your reply (same to @StingerGT68).
(edit to add: giving it a week to "cure" didn't seem to make any difference. One of my earlier "repairs" was to a glancing debris ding near the right headlight, which of course has been "curing" for weeks by now. Sanding it down gently produced exactly the same darkening as the recent "repairs" that had dried overnight.)
