Eli
- Jan 16, 2018
18 psi is map 2 right?
Map 2 is +4psi, which from what I can see only goes to 15 ish psi. Perhaps there's a difference between AWD and RWD?
Very interesting. I'm showing 17.3 max in the app, I wonder what it actually reads...Map 2 show 18psi when I log before.
I will be when I get my canbus cable in to see where the afr are at. I'm going for 20psi.So you're going to run map 3 then. You could do it with a laptop. Just put your desired PSI in the value block.
Very interesting. I'm running map 5 right now that shows 17.3 in the app, I wonder what it actually reads...
I thought stocl boost was 12psi? Wpuldnt it make it 16psi since map2 is 4psi over stock, plz correct me if im wrong18 psi is map 2 right?
Nvm for some reason i missed the previous conversations, this has already been stated lolI thought stocl boost was 12psi? Wpuldnt it make it 16psi since map2 is 4psi over stock, plz correct me if im wrong
That may be an overboost situation (0236). But the first code in the list is what matters. Always try to figure out which code is first. Subsequent codes are often just symptomatic of whatever made the first code appear.
I'd disconnect and inspect the connectors on both the OEM plugs and those on the JB4 cables, re-install carefully, and give it another shot, I guess.
Does that mean your change didn’t help? Sorry just confused by the last sentence.
Excellent. NOw that I read it slower it makes sense.Change fixed it. Did a poor job of explaining. Prior to the change I’d only get 20 miles or so before the CEL came on. I did 100 yesterday without a problem.
