XXR 559 19*8.5 19*10 On SWP Stinger
KLR STINGER
Got my wheels mounted up today.
Wheels: XXR 559 in flat graphite
Size: 19*8.5 Fr 19*10 RR
Offset: +40 F&R. Fronts needed 5mm spacer to clear brakes
Lugs: black acorn tuner style M12*1.5 pitch
Love how it came out. Looks amazing Offsets are dead flush with fenders. 285s look so meaty on back. Wider track and rubber can really be felt felt in corners and improved stability. Ran it up to 160kph with no vibration or wierdness. Just needs to be lowered ASAP! Btw.. You would not believe how cheap these are.. If you can find them! On to pics...
looks great , but the rears look outside the wheel wells ? Can you post a rear shot ?
Nope... they are dead flush. Though some angles does seem like a little poke. I'll get a good rear head on shot, and you'll see a bit better.
Here is the rear profile. you can see its dead flush with top of fender. I think the wheel well gap is causing the illusion of more poke. Once its lowered should be better.
I like the style, the offset in the rear isn't working for me atm. It just looks... weird I guess.
Just IMO. No offence intended.
Thanks for this!!
I know these wheels are offered in 8.5front 35 and 10 rear 15 offset. That would never work without spacers?
Like your spoiler. Which model/type is iot please?
What size are the tires? Back must be 285 30 19s, what is in the front?
it would work. I have 255/40s for my winter set on the rear 10"
Can i see what it looks like?
And does the +20 (i want the concave look) offset makes it more susceptible to just breaking that's why you got +40 or are these wheels reliable for everyday drive? the roads in Montreal or going to ottawa is shit man. and i don't want to be drive 100kph.
The fast aristo is almost identical
I wasn;t sure if the + 20 would work on the front since I was lowere, hence why I went with the +40. In hindsight I know it will work now unless tire is bigger/taller than 255/35 up front when lowered, or 255/40 not.
I got the H&R springs. But 255s huge so i think the 235 will be okay. I wanted to keep that side wall height.
Heck I might just go with the fast aristo's 8.5&9.5 30 offset.
I know this is an old thread but i actually just bought this exact same setup but need help with getting spacers in the front. Can you provide a link of the ones you have?
+32 offset front slight tuck ,zero rubbing, I go a half inch lower. But I don't want to start dragging my front lip
