Burger Tuning JB4 0-60 Time with Map 2
Kamauxx
5000 Posts Club!
I decided to make a video to showcase the JB4 Map 2 (4 psi over stock) acceleration.
4.07 to 60 mph.
And as seen previously, 4.30 to 60 with Map 1 (3 psi over stock).
The car should hit 60 in sub 4 seconds if I could figure out how to warm up the tires without the ECU pulling power.
4.07 to 60 mph.
Sub 4 0-60? Mind blown.
Man if I could figure out how to completely disable the car's nannies. I guess a rolling burnout would be best, if the ECU allows it. I haven't tried yet.
You have the RWD model correct? I'm wondering if so, how the times would differ with added traction of AWD.
On a side note, I missed the delivery of my JB4 today and sig was required. Pissed. I contacted them to keep it at the PO so I can pick it up on my own time. Won't be able to play this weekend :(
Yea I have RWD. AWD should certainly have more traction but it also weighs another <200lbs so it would probably be close to the same. Traction is definitely an issue. The tires break loose each time the car shifts.
That sucks I was looking forward to reading your review today. I love reading people's excitement. So Monday then?
I'm hoping Monday. However, I usually finish work around 6pm on Mondays so I will probably miss my opportunity. Most likely Tuesday. ARGH!
Guys, I just got my car back from the dealership after it sitting for almost 3 weeks...
I plan on having both my springs installed and my plugs gapped this week and will toss the JB4 back on.. I don’t want to go through that again
I plan on having both my spings installed and my plugs gapped this week and will toss the JB4 back on.. I don’t want to go through that again
What? Why was it there for 3 weeks?! Waiting for coils and plugs? And if so, 3 weeks to wait for coils?! Holy heck I'm sorry you had to go through that. But it's because of you and other early adopters that we are learning of the problems and avoiding them hopefully. Thanks and hope moving forward you can start enjoying the extra power!
Get wider tires for the rear!! Thanks for posting this!
200lbs heavier, but the main thing with these cars in awd, is that it sends up to 80% of power to the rear tires anyways, i think the awd was designed for handling more than dig runs
Is it bad to run map 1 without changing the plugs?
